Perform the following procedure to configure the PoE power limit for specific ports or channels. You can limit the PoE wattage available from an individual port or list of ports.
Variable definitions
The following table defines parameters for the poe-limit command.
| Variable | Value |
| <portlist> | Identifies the ports on which the limit is set. |
| <power_limit> | Specifies the configurable power limit, in watts on a particular port. To see the available range for the switch, use the CLI Help. |
